TwinTurbo.NET: Nissan 300ZX forum - Re: extremely weak injector click and spark when spinning CAS
Luminar
on March 23, 2014 at 7:20 AM
posted by LivinTheDream
on March 22, 2014 at 10:23 PM
Check your fuel pressure. I've had the injectors sound extremely weak because the pressure was only like 8 pounds in the rail. Car would also obviously not run
LivinTheDream
22:23:11 03/22/14
Is this on all cylinders, both on a single cylinder, or...
-Grimm-
00:30:25 03/23/14
its all of the injectors and i only checked the number one
LivinTheDream
01:33:30 03/23/14
I've never had one grounded there
-Grimm-
02:57:43 03/23/14
it will no longer start. i feel it maybe wiring. (n/m)
LivinTheDream
05:18:29 03/23/14
Re: extremely weak injector click and spark when spinning CAS -
Luminar
07:20:58 03/23/14
point taken but there should still be a audible sound of
LivinTheDream
12:31:23 03/23/14
did you test between the filter and dampener? also is the
LivinTheDream
17:47:35 03/23/14
so i checked over just about everything today. i verified
LivinTheDream
17:59:24 03/23/14
What maintenance were you performing?
-Grimm-
18:05:55 03/23/14
replaced t-belt pulleys, studs, belt and full engine repaint
LivinTheDream
19:50:11 03/23/14
